ATTiny4313 trying to implement a delay() function using Timer1 but it's not generating the delay
ronnygrr
Joined Mar 30, 2024
5
I am working on a crosswalk project using an ATTiny4313 and the clock is set in the simulator as 8Mhz. The rest of the code works fine, I have made multiple tests and I am pretty sure it works. I have to generate delays using interruptions, in this case, I am generating the interruption by comparison between the Timer 1 and the OCR1A register. As you can see in the code, I set that register as 255, so according to the datasheet, by this equation and using 1024 as the prescaler:
1712991466733.png​
The f_{OC} will be 15.26 Hz, which would be 65.5 ms of period T, which means that every 65.5 ms I am generating an interruption, from what I can understand. My subroutine is simply increasing an int variable called segs, so the delay function I made is pretty simple. What I want my code to do, to test the correct functioning of this delay is to blink an LED and leave it ON for whatever the argument in seconds I pass to it, so that if call it like delay(2); it should do nothing for that amount of time but turns out my LED stays ON forever, I have tried everything but nothing is working, maybe I could get some help in here.
This is the hardware:
1712991855077.png​
And this is the code in C:
C:
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
// Pines del semáforo peatonal 1
#define RED_PEATON1 PB7
#define GREEN_PEATON1 PB6
// Pines del semáforo peatonal 2
#define RED_PEATON2 PB5
#define GREEN_PEATON2 PB4
// Pines del semáforo vehicular
#define RED_VEHICULAR PB3
#define GREEN_VEHICULAR PB2
// Definición de los estados para la FSM
#define esperando_boton 0
#define blink_vehicular 1
#define detener_trafico 2
#define blink_peatonal 3
// Variables globales del programa
int boton;
int segs = 0;
int un_seg = 0; // Un acumulador
int tres_segs = 0;
int diez_segs = 0;
// Preambulo de funciones
void boton_init();
void timer_init();
void cruzando();
void detenido();
void delay(float seconds);
// Interrupciones
ISR(INT0_vect){ // Subrutina que alterna B1 entre 1 y 0
    boton = !boton;
ISR(TIMER1_COMPA_vect){
    segs++;
// Inicio de la función main
int main(void)
    boton_init();
    sei();
    timer_init();
    DDRB |= (1 << RED_PEATON1) | (1 << GREEN_PEATON1) | (1 << RED_PEATON2) | (1 << GREEN_PEATON2); // Pines de semaforos peatonales como salidas
    DDRB |= (1 << RED_VEHICULAR) | (1 << GREEN_VEHICULAR); // Pines del semáforo vehicular como salidas
    boton = 0; // Inicializo la variable B1 en 0
    while (1)
        if (boton == 1)
            for (int i = 0; i < 10; i++)
                PORTB ^= (1 << RED_PEATON1);
                delay(2);
            boton = 0;
        } else
            PORTB &= ~(1 << RED_PEATON1);
// Final de la función main
// Funciones del programa
void boton_init() { // Se establece para detectar flancos positivos en el pin PD2
    GIMSK |= (1 << INT0); // Habilitar la INT0 (interrupción externa)
    MCUCR |= (1 << ISC01); // Configurar como flanco descendente
void timer_init(){
    TCCR1B |= (1 << WGM12) | (1 << CS12) | (1 << CS10); // Esto me activa el prescaler de 1024 y el modo CTC
    TIMSK |= (1 << OCIE1A);
    OCR1A = 18; // Esto va a hacer que se genere una interrupción cada ~10ms
void cruzando(){
    PORTB |= (1 << GREEN_PEATON1)| (1 << GREEN_PEATON2) | (1 << GREEN_VEHICULAR);
    PORTB &= ~(1 << RED_PEATON1) & ~(1 << RED_PEATON2) & ~(1 << RED_VEHICULAR);
void detenido(){
    PORTB &= ~(1 << GREEN_PEATON1) & ~(1 << GREEN_PEATON2) & ~(1 << GREEN_VEHICULAR);
    PORTB |= (1 << RED_PEATON1) | (1 << RED_PEATON2) | (1 << RED_VEHICULAR);
void delay(float seconds) {
    TCNT1 = 0x00; // Reseteo del timer 1
    segs = 0; // Reseteo a la variable segs
    while (segs < 15*seconds) {
        // No haga nada
35,245
In English, we don't say "interruption and interruptions". We say "interrupt and interrupts".
Have you checked that the delay( ) function by itself works?
ronnygrr
Joined Mar 30, 2024
5
Thank you, it's not my first language. And yes I did and it's not working, it's actually what I've been trying to fix, you got any ideas?
35,245
I would begin by testing a simple loop such as the following:
C:
while (1)
   delay(2);
What software debugging tools are you using?
Do you have access to an oscilloscope?
For testing, try replacing the delay( ) function with a software version, using very large delay values. An LED flashing very rapidly would appear as if the LED was on all the time.
C:
void delay(long int d)
   while (--d);
ronnygrr
Joined Mar 30, 2024
5
C:
while (1)
   delay(2);
C:
   while (--d);
I am doing that, actually that's how i began debugging that code, I provided all of it as a way to give more context, but its really not doing anything it's like if it never passes the line when it turns ON.
C:
PORTB |= (1 << RED_PEATON1);
delay(2);
delay(2);
35,245
So, your delay( ) is not working.
Can you check that you are actually getting TIMER1 interrupt requests?
Does your IDE allow you to set break points? If not, toggle an LED every time an interrupt is received.
Jony130
Joined Feb 17, 2009
5,601
This version works in the Atmel studio simulator and in proteus win ATtiny2313.
C:
#include <avr/io.h>
//#include <util/delay.h>
int boton;
uint16_t segs = 0;
int tres_segs = 0;
int diez_segs = 0;
void boton_init();
void timer_init();
void cruzando();
void detenido();
void delay(uint16_t seconds);
// Interrupciones
    boton = !boton;
    segs++;
int main(void)
    boton_init();
    sei();
    timer_init();
    while (1)
        //if (boton == 1)
                delay(2);
            boton = 0;
        //} else
        //    PORTB &= ~(1 << RED_PEATON1);
void timer_init(){
    TCCR1B |= (1 << WGM12) |(1 << CS12)| (1 << CS10); // Esto me activa el prescaler de 1024 y el modo CTC
void cruzando(){
void detenido(){
void delay(uint16_t seconds) {
        // No haga nada
And this works on a real hardware ATmega32.
C:
 * main.c    ATmega32A    F_CPU = 16000000 Hz
 * Created on: 14.04.2024
 *     Author: admin
#include <avr/io.h>
#define RED_PEATON1 PC0
uint8_t volatile segs = 0;
void boton_init();
void timer_init();
void delay( uint16_t seconds );
// Interrupciones
ISR( TIMER1_COMPA_vect ) {
    segs++;
int main( void ) {
    boton_init();
    timer_init();
    sei();
    while ( 1 ) {
        PORTC ^= ( 1 << RED_PEATON1 );
        delay( 1 );
void boton_init() {
    DDRC |= ( 1 << RED_PEATON1 );
    PORTC |= ( 1 << RED_PEATON1 ); //RED_LED_OFF  (ANODE to Vdd)
void timer_init() {
    TCCR1B |= ( 1 << WGM12 ) | ( 1 << CS12 ) | ( 1 << CS10 ); // Esto me activa el prescaler de 1024 y el modo CTC
    TIMSK |= ( 1 << OCIE1A );
    OCR1A = 155; // Esto va a hacer que se genere una interrupción cada ~10ms
    TCNT1 = 0x00;
void delay( uint16_t seconds ) {
    while ( segs < ( 10*seconds ) ) {
        // No haga nada
