Attic fan quit, 5mfd run capacitor reads open
sdowney717
Joined Jul 18, 2012
805
Couple days ago, fan quit, uh oh. Noticed it was hotter upstairs.
When powered on motor buzzes. Spin fast by hand it runs.
Takes some force to spin it up as it feels magnetized. Spins free with power off.
I ordered two new 7.5 capacitors.
Do you think the old run cap failed?
The old run cap is more than 15 yrs old. Maybe even 20. I pulled it out of an old gas furnace I bought long time ago which I never used just to get this replacement motor for the fan to run.
What I did like is the thermal protection on GE motor works. Yesterday when going into attic, power was on, no motor hum.
Turned off power to motor.
This am turned on power, motor hums, looks like barely rotates a few degrees. Means to me thermal protection works.
Noticed when powered on and it hums the attic light very subtly dimmed, motor drawing lot power.
Looked at copper windings, they are shiny bright, bearings not worn.
I ohmed the low speed yellow wire to white wire, still good about 3.5 ohms, tells me the coils are good.
MisterBill2
Joined Jan 23, 2018
28,271
Is this a different fan motor? Capacitors do fail eventually. AT least it looks that way. And some times it appears that some fan motors do not use capacitors. I have had a lot of use with an older WESTINGHOUSE "3 speed electrically reversable" window fan I acquired used 45 years ago. It sits in a window and discharges the warmer air out. it has never had any problems, except that the mechanical control thermostat no longer will switch it off when the air gets cooler.
I have given it a few drops of #30 oil over the years. A quart can lasts a long time when used for a few drops a year.
30,808
Did you replace the caps?
Are they motor run rated, and not of Chinese origin?
If thermally protected, it should not try to turn at all or hum , when powered, with the thermal trip operated.
If you spin it by hand and apply power, does it spin?
sdowney717
Joined Jul 18, 2012
805
It definitely runs if I turn by hand, but the on switch is 20 feet away.
so, I turned it on, and it was humming, I crawled over to fan and spun it hard, and it ran.
Somewhere I have a capacitance meter and can't find the thing.
sdowney717
Joined Jul 18, 2012
805
New cap, motor runs fine.
Happy to see that.
I bought 2 to have a backup. I read these caps are failing more so than they used to.
sdowney717
Joined Jul 18, 2012
805
back to not working.
It just hums when it tries to start
I will have to take it down and take it all apart and think about what is going on with it.
Is there more than one thermal protection breaker in this motor?
Are these GE furnace, air handler blower fan motors not rated to run in attic temps?
LowQCab
Joined Nov 6, 2012
5,102
The built-in Thermal-Protector may get weak after repeated overheating episodes.
I would replace the whole Fan,
it's probably cheaper to buy a new complete Fan than to buy a replacement Motor alone.
30,808
I have found the N.A. or non Chinese versions start caps to last many years.
Try giving it a spin when applying power and see if it runs,
If it does, try a spin in both directions at start, and see if it favors just one dir.
If there were any other thermal device it should cut power completely.
sdowney717
Joined Jul 18, 2012
805
Ok. I spin backwards. Turn on power it stops and slightly spins other way then quits. I spin correct rotation. Turn on power. Motor powers on and continuously runs so far. I turned thermostat so it will never turn off. Doing this to see if it stays running all day in hot attic.
sdowney717
Joined Jul 18, 2012
805
Still running. Bearings dont have play. If bearings are loose could magnetic field unevenly pull on rotor? Preventing starting?
sdowney717
Joined Jul 18, 2012
805
Tried holding second 7.5 cap on terminals of existing 7.5 cap and half the time it started. Tried a new supco 5mfd and would not start.
With 2 7.5, sometimes would spin half turn, quit and hum.
