Using leftover solar panel to ventilate attic
Miamibuilder
Joined Sep 3, 2017
I have a leftover solar panel that I want to use to ventilate my attic. The panel is a Evergreensolar es-a-210-fa3 about three by five feet. Can someone suggest a fan and other components to use this panel and where can I purchase them? Thanks, first time on your site.
WBahn
Joined Mar 31, 2012
33,178
MOD NOTE: Please stop hijacking long dead threads. Start your own using the "Post New Thread" button in the forum where you want to create the thread.
38,788
Finding a large DC powered fan could be difficult.
You could use a DC-AC inverter to generate 120Vac and use that to power a standard attic fan.
Alternately you could use a 12V fan, such as this, but you would need some type of regulator to limit the voltage from the panel.
ebeowulf17
Joined Aug 12, 2014
3,307
When, and for how long do you want the fan to run? Are you expecting it just to run just when there's enough sunshine? If not, you're maybe looking at batteries and a charging system too.
Sensacell
Joined Jun 19, 2012
3,787
The simplest idea would be to use multiple 24v DC fans, connected in parallel.
They will run a bit slow, but it's dead simple.
Trying to find one big DC fan will be far more difficult and expensive than just using a bank of small cheap ones.
