MaxHeadRoom
- Joined Jul 18, 2013
- 30,772
The one I obtained was an industrial style, designed specifically for the job intended, works fine.
Did you replace the caps?I ordered two new 7.5 capacitors.
Do you think the old run cap failed?
The old run cap is more than 15 yrs old. Maybe even 20. I pulled it out of an old gas furnace I bought long time ago which I never used just to get this replacement motor for the fan to run.
Put hand on motor and it's hot. Can keep hand on it.Bearings can definitely cause a problem on motors such as these.
A current meter would be best to check start cap.
