djsfantasi
- Joined Apr 11, 2010
- 9,237
You STILL have delay_microseconds() calls in your ISR, zero_crI build on bread board the attached schematic and I uploaded the attached code to an Arduino Uno.
I tested each part of the schematic (the pot, the OpAmp, the zero crossing detector, the optotriac) and they are working.
The problem is that when I start the circuit I got the attached screenshot from the oscilloscope, and if I rotate the pot, then nothing happens. Also, the heating of the soldering iron does not stop.
What should I do ? I tried different types of modifications in code, for example making some variables from int to long or from long to int, reading in the zero crossing function the value of the pot.
C:#include <PID_v1.h> int firing_triac = 1; // OUTPUT TO CONTROL TRIAC int zero_in = 2; // INPUT FROM ZERO DETECTION double value_zero = 0; int pot_pin = A1; int temperature = 0; //Define Variables we'll be connecting to double Setpoint, Input, Output; double lastupdate; double newSetpointPot; double newSetpoint; double consKp = 1, consKi = 0.05, consKd = 0.25; //Specify the links and initial tuning parameters PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT); void setup() { myPID.SetOutputLimits(0, 220); myPID.SetMode(AUTOMATIC); lastupdate = millis(); Setpoint = 0; pinMode(firing_triac, OUTPUT); // Set the AC Load as output pinMode(zero_in, INPUT); digitalWrite(zero_in, HIGH); // pull up attachInterrupt(0, zero_crosss_int, RISING); } void zero_crosss_int() // function to be fired at the zero crossing to dim the light { int dimtime = (40*Output); delayMicroseconds(dimtime); // Off cycle digitalWrite(firing_triac, HIGH); // triac firing delayMicroseconds(10); // triac On propagation delay digitalWrite(firing_triac, LOW); // triac Off } void loop() { Input = 0; for(int i=0;i<50;i++) Input += analogRead(A0); Input /= 50; Input = map(Input, 0, 550, 25, 400); temperature = Input; newSetpointPot = analogRead(pot_pin); newSetpoint = map(newSetpointPot, 0, 1023, 150, 400); //Display setpoint if (abs(newSetpoint - Setpoint) > 3) { Setpoint = newSetpoint; temperature = newSetpoint; lastupdate = millis(); } myPID.SetTunings(consKp, consKi, consKd); noInterrupts(); myPID.Compute(); interrupts(); //delay(1000); }
THEY WON’T WORK!
Did you read the documentation I linked to? It clearly states that several statements, including delay() and delay_microseconds do not work in an ISR.
How can we help you if you refuse to listen?
