Arduino Automatically Selects Power Source
waulu
Joined Dec 23, 2016
62
I was looking at the schematic of Arduino Uno and the way it selects the power source. I have attached the schematic, the circuit that I have doubts is located on the top part of the sheet.
When both sources (External and USB) are connected, the P-MOSFET will be turned off, but the diode will allow current to flow. Couldn't this situation cause problems? So if 5V_USB_Voltage is a little bit higher than the 5V_Regulator, a current will flow to the 5V_Regulator. On the other hand, there's a drop voltage across the diode, so after the diode, it appears a voltage 5V_USB_Voltage - Diode_Forward_Voltage, let's imagine that's 4.3V. I have attached an image to clarify my doubt. What happens in the situation?
AlbertHall
Joined Jun 4, 2014
12,625
If the external power is connected then IC2 will be regulating that eternal power to the +5V rail. This means that the voltage across the diode will be close to zero so no current will flow.
waulu
Joined Dec 23, 2016
62
Thank you, forget that thing about the 4.4V, I just made a mistake =)
Ok, according to the USB 2.0 specifications, VBUS range from 4.75V to 5.25V, and the IC2 (MC33269) has an output tolerance of 1%, that means 4.95V to 5.05V, worst-case scenario, 5.25 V - 4.95V = 0.3 V.
Now I would like to know how much current could cross the diode. According to the datasheet of the P-MOSFET (FDN340P),
Is this the right graph? At 25ºC the current across the diode is less than 0.0001 A but at 125ºC is about 0.002 A.
