Anyone knows what this IC is?
FlllP
Joined Jul 19, 2025
108
Follow post #39
So voltage on these two pins is around 28.8, and it's kinda dancing like 28.7 to 28.8...
So far I replaced diodes, capacitors, the coil, those 2 transistors, that chip... the only thing I didn't replace is that dark green capacitor and that light green inductor, also those two beige resistors, but i checkted them and they are ok...
also I tried Control board on 9V battery ( connected on same pins as where i measured voltage) and it worked, but when i connect it to the board, it just repeatedly beeps... I also tried to connect only those two pins to the board, same issue...
What I see, it's that there is ma voltage for AMS1117 3.3V is 15V, but the pins output ~28V... so could that be the issue, but then, wouldn't AMS1117 just burn out, or break, and the board wouldn't continuesly beep?
FlllP
Joined Jul 19, 2025
108
So I have Gorenje Panel heater "optiheat 2000 ewp" it have 2 boards, control board and power board, and it looks like something on power board went wrong.
This is the continuation of this thread here: Forum Thread
I have attached the photos of the board!
Irving
Joined Jan 30, 2016
5,154
The regulator could be outputting a low voltage - enough to beep but not enough to do anything useful... or a higher voltage, which means possibly the board is fried and all it can do is beep.
FlllP
Joined Jul 19, 2025
108
The control board works fine on 9V battery, that's why I'm confused. But when I connect those 2 pins to the power board it just beeps repeatedly.
Irving
Joined Jan 30, 2016
5,154
Its switching quickly from 10V to 20V
Ouch, you're lucky the downstream MCU etc are still alive, but not for much longer I suspect, that'll be stressing them badly. Clearly the regulator is unhappy with that input voltage; it's in some strange world of its own. You need to check it with a 12v input from a wall-wart or LiPo battery pack that has sufficient current delivery capability, around 1A should do it, to see if it is actually working ok.
FlllP
Joined Jul 19, 2025
108
But I can't figure out what the issue is.
so, i have atthed it to around 6V on AC pins..
and here are the measures:
1-2 = 12V
1-3 = 18V
1-7 = 12V
5-4 = 13.5 and slowly climbing
1-6 = 6V
Let me find 12V charger
FlllP
Joined Jul 19, 2025
108
Another thing, When i disconnect board, the volate is climbing to around 12-13 volts on pins 5-4, but when i connect the board its in milivolts... that is on 12V battery charger... So i don't know what is going on...
Irving
Joined Jan 30, 2016
5,154
Measure voltages:
X-X on AC volts (>90V expected, take care )
A-G, B-G, C-G on DC Volts (probes as colour shown).
(>90v, >90v, <20v)
FlllP
Joined Jul 19, 2025
108
Measure voltages:
(>90v, >90v, <20v)
Soo, I measured in DC mode:
AG = 328V
BG = 328V
CG = jumping fast between 38V and 48V, like one second its 38V and another its 48, and it jumps like that...
G and pin next to C is 28V
In AC mode:
XX = 237V
Irving
Joined Jan 30, 2016
5,154
hmmm - I think one of those capacitors below the IC is breaking down... most likely the green one, but I'd probably replace all three to be sure.
FlllP
Joined Jul 19, 2025
108
I replaced all electrolytic capacitors, I don't have replacement for the green one, but I will find it somewhere hope so
FlllP
Joined Jul 19, 2025
108
Replaced Green one, its still the same issue, still getting 28V for the control board
FlllP
Joined Jul 19, 2025
108
Yes, but yours is more like the reference circuit earlier in the datasheet, and exactly the one I drew from your circuit board in post #22
Yeah, I am trying to figure out why is it going above 12V when PN8024R should output 12V, not above it, but im getting like 28V...
Irving
Joined Jan 30, 2016
5,154
Do you have an LCR meter to measure inductance? The only other reason for the output being wrong, assuming the chip isn't faulty, is a wrong inductor value - maybe it has an internal short.
