Pseudo Random Binary Sequence / Feedback Shift Register. Can anyone explain?
brianmk
Joined Dec 23, 2016
109
I have been experimenting with a Pink / White Noise generator using a PRBS.
I have played around with a number of different shift register lengths using XOR feedback from two stages to give maximum length sequences. Tables of suitable lengths and taps can be found online.
What I have found is that when I use feedback from the last two stages, I get what appears to be single bits within the pattern that repeat such that they appear stable when viewed on an analogue 'scope.
For example, a 15 stage FBSR with feedback from stages 14 and 15 gives a pattern like the one below.
(20uS/div, clock frequency approx 100kHz). The expected PRBS length is 2^15-1 = 32767 bits.
I see a similar effect for other SR lengths where feedback is taken from the last two stages. For other tap points, I just see random data as expected. Can anyone explain what I am seeing? Is it just a 'scope triggering artefact or is there something wrong with the random sequence?
The 'scope seems to be triggering on the rising edge of a repeating '1' bit such that the '0' a few bits later in the sequence appears stable. Note: I only observe this effect when using SRs with feedback from the last two stages.
The distance between the stable '1' and '0' bits corresponds to the overall SR length i.e. 15 bits in this example.
panic mode
Joined Oct 10, 2011
5,463
the circuit creates perfect x⁵⁷ + x⁷ + 1 (same as x⁵⁷ + x^50 + 1). so mathematically this is solid. what likely causes issue is a bit too short reset (C19/R16). if that does not help, there may be timing issue (even though they are clocked by same signal). you may want to try inverting clock for one of them. for example on 4557, tie pin 4 low, and use pin 5 as clock.
brianmk
Joined Dec 23, 2016
109
A couple of sensible suggestions 'panic mode' but I have already ruled those out...
It's not the reset. I added a temporary push button switch that allows a manual reset. It makes no difference to the issue. The crude CR power on reset works fine despite the slow rise/fall time.
I had already considered that it might be down to timing or a race condition between the clock edge and the combinatorial XOR or XNOR logic. I had already tried inverting the first stage clock in the 4557 so it uses the negative edge while leaving the 4094 using the positive edge. That made no difference.
I have also tried arranging the feedback such that both signals are derived from the 4094 'Qn' outputs rather than having one fed from the 4557 output (i.e. the 4094 data input). That also made no difference.
I have two versions of the circuit: One on a breadboard so I can play around with the SR length and feedback taps and another on a PCB. Both behave the same way so I doubt it's related to power supply noise or glitches. I am using different power supplies for each. Perhaps it's not a fault at all. Is there a mathematical explanation? Chat GPT offers no help.
Incidentally, if I set the 4557 to 16 stages and use Q2 and Q7 from the 4094 for the feedback, the configuration matches that used in the original Project 182 from 'Elliott sound' (He uses three 8bit 4094 SRs). With this configuration, the feedback is not derived from the last two stages so it works as expected: I get random data with no repeating fixed '0' or '1' patterns.
One of the problems with using 4094s only is that they have no reset pin. The original circuit uses AC coupling and a pull up resistor on the first stage to avoid all 1's or all 0's. However I found that solution to be unreliable - it can lock up.
I am wondering if I may have fake or faulty 4557 or 4094 devices. I'm going to try and order some from another supplier to check. They are probably obsolete in DIP form.
panic mode
Joined Oct 10, 2011
5,463
i remember trying ChaptGPT couple of times and gave up. results were useless. nowadays if i want to chat with AI, i use Grok or Google AI. Grok is pretty good but free version ends current session after certain number of exchanges so i use it less and less.
here is what Google AI came up with:
With a low clock frequency of 60–150 kHz, timing or race conditions are completely out of the equation. Knowing that the original circuit called for three CD4094s (24 bits) instead of your current configuration confirms exactly why you are observing a precise two-bit dropout.
The issue stems from a classic mix-up in how the CD4557 calculates internal bit length compared to standard shift registers.
The Source of the Two-Bit Shift Error
A standard shift register (like the CD4094) operates under a simple rule: if you want a length of 8, you read the 8th output stage.
The CD4557 does not work this way. It is internally hardwired with an baseline minimum offset. Its logic formula for programmed bit length is:
\(\text{Total\ Bit\ Length}=\text{Sum\ of\ Binary\ Programming\ Pins}+1\)
Because you have \(L_{1}\), \(L_{16}\), and \(L_{32}\) tied to \(V_{CC}\) (\(1 + 16 + 32 = 49\)), the CD4557 adds its internal fixed \(+1\) offset to provide a total shift length of exactly 50 bits.
The 2-Bit Discrepancy
If the original audio noise circuit used three CD4094s (providing a total shift length of 24 bits) and tapped Q7 of the final register, the original master tap position was exactly at bit index 23 (\(8 + 8 + 7 = 23\)).
When adapting this circuit to use a CD4557 to replace the first two CD4094s (\(8 + 8 = 16\text{ bits}\)), the designer likely intended to replace those 16 bits directly. However, notice the mathematical shifts:
  • If the designer set the CD4557 to a targeted "\(48\)" bits to shorten a large loop, or calculated a substitution for a larger cascading array, changing the physical component alters how the feedback loop lines up.
  • By adding 50 bits (from your CD4557 setup) to the 7 bits of your CD4094, you have a 57-bit total loop.
  • If the primitive math for the noise generator's original pseudo-random polynomial expected a specific tap-to-tap balance (for instance, an exact 2-bit delta or a specific 2-bit spacing within the 24-bit window), the internal \(+1\) calculation rules of the CD4557 shift the phase positioning exactly wide.
Because the CD4557 introduces a +1 delay that doesn't exist on bare cascaded pins, and because your bit count is precisely two counts off what a clean multiplication would give, the data stream is arriving at the XNOR feedback gate two clock cycles late.
The Result on Your Scope
Because the feedback data arrives two clocks late, the XNOR gate generates a correcting bit that cancels out or mimics the previous states for exactly a two-cycle window. In an LFSR, when the feedback polynomial is thrown off by exactly a 2-bit phase delay, it forces the register stream to produce a repeating dead zone where two consecutive bits are crushed down to zero (00) every single time the sequence loops.
How to Fix It
To fix the two-clock dropout, you need to subtract 2 bits from the CD4557's programming array to pull the timing back into phase alignment:
  1. Look at your programming pins: \(L_{32}\) and \(L_{16}\) equal 48.
  2. Disconnect \(L_{1}\) from \(V_{CC}\) and tie it to GND.
  3. This changes your calculation to: \((32 + 16) + 1 =\) 49 bits.
  4. If it still shows a 1-bit shift on the scope, disconnect \(L_{16}\) and pull up \(L_8 + L_4 + L_2 + L_1\) to walk the variable length explicitly down until the phase-canceled dead zone disappears.
like any AI, it is not infallible but it did offer an interesting suggestion that is easy to try on your breadboard version.
drjohsmith
Joined Dec 13, 2021
1,677
where are you tapping off of ?
remember the first register is tap 1, not zero.
remeber that for an xor , the all zero is invalid, for xnor, the all 1 is invalid,
also remember not all lfsr are just 2 taps from last bits ,
it looks to me as if you actualy have just an inverter , not an xor , so you end up with 15 bits 1, then 15 bits low
brianmk
Joined Dec 23, 2016
109
I am not convinced the Google AI above gives the right answer...
It seems to be basing it's analysis on the schematic I uploaded.
It's confusing because that particular configuration does NOT exhibit the problem when I try it.
The schematic has the 4557 length set to 49+1 = 50.
XNOR feedback from comes from taps 50 and 57 i.e. 4557 Q output (stage 50) and 4094 Q7 (stage 57).
This matches the length and tap data given in online tables for maximum length FBSRs.
The problem only manifests itself when the taps come from the last two stages.
In my original example I used a shorter 15 stage SR with feedback from 14 & 15.
(This is easier to see on an analogue 'scope)
For this I set the 4557 to L32=0, L16=0, L8=1, L4=1, L2=0, L1=0. i.e. 12
That gives a 4557 SR length of 12+1=13 stages.
I took XNOR feedback from the 4094 Q1 (stage 14) and Q2 (stage 15).
This configuration does exhibit the problem.
I tried to apply the AI solution to the 15 stage configuration:-
If I reduce the 4557 length from 13 to 12, all that happens is the gap between the scope trigger point and the fixed '0' bit is reduced by one clock pulse. If I reduce the length to 11, the gap reduces by two clock pulses.
drjohsmith
Joined Dec 13, 2021
1,677
When you have the 14 registeres if the smaller shifter
Put scope probe on the two inputs of the xor / xnor
Check you have a period when the two inputs are different. .
Then check the output of the xor / xnor. You should see a pulse the width of the time the two inputs were different.
What you have is a circuit error.
AI will not correct that for you as it can't see your actual writing.
brianmk
Joined Dec 23, 2016
109
How does that explain why the problem goes away if the taps are not from the last two SR stages?
For example a 17 stage SR with taps at 14 and 17 does not exhibit the problem.
drjohsmith
Joined Dec 13, 2021
1,677
Because you have a circuit problem
You evidently have either a broken system or your moving / changing something that you don't realise.
The only other explanation is that hundreds of years of logic design was wrong , and you have found the problem .
This is not software , it's hardware . The clue is in the name , it's hard ...
To debug hardware , look at what's happening , measure , and make educated guess what needs to be to cause that..
Then probe / test that hypothesis.
Show us a picture of your test circuit please.
Confirm you can not have 15 registeres not 16.
These are called polynomials
Many forms .. what your looking for is the maximum length lfsr taps .
If you have 15 taps , and your getting out a square wave , 15 low , 15 high , then you have an inverter on the output not an xor .
My bet is one of the inputs to the xor is a fixed level , thus making the xor an inverter of the other bit.
Hence my suggestion on how to scope the xor and tell what's happening ..
panic mode
Joined Oct 10, 2011
5,463
with U1 and U3 max number of stages is 64+8=72. the only LFSR-2 that have taps on the last two bits are n=15, n=22 and n=63
since 57-stage works, let's review it first:
U2A is an XOR followed by U2B wired as inverter. so together they form an XNOR gate.
since that is a single 2-input gate, 2 tap configuration is possible (LFSR-2).
with L1,L16 and L32 high, this should be (32+16+1)+1=(49)+1 = 50 stages in U1.
U3 is an 8 stage register but the output (C10/R2) is from Q7 so last stage (Q8) is not used. 50+7=57 stages.
According to the Standard Table of Linear Feedback Shift Registers, a 57-bit length can run flawlessly
on a single 2-input XNOR gate (LFSR-2), but only IF the feedback taps are at bit 57 and bit 50 - which seem to be the case here.
there are other LFSR-2 possibilities but only some of them can be used here since U1 only has single output - so taps must be on U3 signals only.
that rules out 55-bit and 58-bit lengths for example but 47, 52 and 57-bit lengths are fine.
since gate is configured as XNOR, all 1 state is invalid which is avoided by reset (only U1, via C19/R16). duration of reset is not critical - as long as some bit(s) are reset, this should run fine.
while U1 and U3 are different chips, they are clocked from same source and low frequency (~60kHz), syncing cannot be the issue.
bypass capacitors are across each IC which is correct though their values is 1/10 of usual 100nF, but that also should not be the problem - as already seen on working 57-stage variant. so hardware is fine. the only problem is with certain choices of taps.
this should have worked. i am guessing that this is not something you can easily change on PCB so it is most likely the breadboard variant. breadboards can be touchy, specially if it is one found in university lab (used a lot). probe L1,L2,L4 etc voltages to confirm if they really match the wiring.
brianmk
Joined Dec 23, 2016
109
I think I have figured it out...
Recall my original question:-
"Is it just a 'scope triggering artefact or is there something wrong with the random sequence?"
After carrying out further tests today using smaller sequence lengths I have concluded that what I am seeing is simply down to the way the signal appears when viewed on a 'scope. I don't think there is anything wrong with the PRBS.
I began by looking at a really short FBSR that uses two XNOR taps from the last two stages.
i.e. 4 stages with feedback from 3 & 4.
For this I set the 4557 to 1+1=2 and used feedback from the 4094 Q1 (stage 3) and Q2 (stage 4).
The PRBS length is 2^4 - 1 = 15.
The short length makes it easy to view the entire sequence on a 'scope.
It all looked fine.
Next I tried 6 stages with feedback from 5 & 6.
The 4557 was set to 3+1=4 with feedback from the 4094 Q1 (stage 5) and Q2 (stage 6).
The PRBS length is 2^6 - 1 = 63.
You can easily see two complete sequences on the 'scope with the timebase set to 100uS/div.
If you increase the timebase to say 50uS/div then you see what looks like single stuck bits in amongst the otherwise random data. The fixed part of the patten changes as you adjust the timebase. It's a kind of 'beat' or 'aliasing' effect.
It seems fairly obvious now but it had me scratching my head for a while.
What made it more difficult is that I don't have access to a modern digital scope or logic analyser.
panic mode
Joined Oct 10, 2011
5,463
one almost $0 option is to drop clock frequency and use computer sound card as scope to capture stream. note, sound card must be protected with back to back diode pair and voltage divider.
drjohsmith
Joined Dec 13, 2021
1,677
It all looked fine.
Well found .
Much better to look and think than to go to AI
arduinolego611 Microcontrollers 4
PeteHL Digital Design 39
