Any simple sine wave generator?
38,851
Can a 500Ω potentiometer be placed in series with R3, and the user can fine tune the amplitude to a fixed, say, 3v by taking advantage of the precision rectifier??
Yes, a pot can be used to vary the output amplitude.
But what do you mean "taking advantage of the precision rectifier"?
vandveuser16776
Joined Feb 21, 2026
230
By delay i meant how long it took to finish 1m tran, which takes 1 sec if you use LT1013.
The precision rectifier is part of the design to measure the voltage across the components ( a resistor and the unknown inductor) which shows real peak as opposed to multimeters set to AC range which show RMS.
This completed design is supposed to be a make-shift inductance meter
AnalogKid
Joined Aug 1, 2013
12,281
So where's this long delay you mentioned?
I think she is referring to my post #73, which goes back to post #59.
In a circuit such as your post #61, inadequate filtering of the rectified output signal at node AGCb can cause the remaining ripple to modulate the gain control device, adding harmonic distortion to the output signal.
ak
38,851
If you are referring to the oscillator with the AGC circuit, that has nothing to do with the op amp model, it's the time-constant of the AGC control loop.
Otherwise, in general, the time it takes to do a simulation is determined by the frequency of the voltage changes in the circuit, i.e. a circuit oscillating at 1MHz will take a long longer for a 1ms simulation, than a 1kHz oscillator.
