- Joined Jan 23, 2018
- 28,495
I am thinking that 8 to ten volts would be reasonable.That puts the transistor current is developing 5 volts across 400 ohms
Thanks MisterBill2. So you think that this circuit would work for say up to perhaps 30MHz?I am thinking that 8 to ten volts would be reasonable.That puts the transistor current is developing 5 volts across 400 ohms
With an adequate input signal it should. My experience with frequency counters is that with some of them, sensitivity does vary with the frequency.T
That is what you get here!This was a big waste of time!
Of course it was. The problem was badly specified at the beginning.This was a big waste of time!
Is that coming from your vast three months of experience?That is what you get here!
Forums are a two-way street. Tell us all about your particular contributions.That is what you get here!
It is also older and crankier than modern devices. It is not suitable for amateur designers.AN LM311 comparator is able to be much faster.
| Thread starter | Similar threads | Forum | Replies | Date |
| T | 3-Way Class D DSP Amp with Analog & Digital Inputs | Analog & Mixed-Signal Design | 8 | |
| M | Analogue SPDT Circuit | Analog & Mixed-Signal Design | 30 | |
| U | Digital, Analog, and Power | Analog & Mixed-Signal Design | 12 | |
Digital & Analog | Microcontrollers | 3 | |
| E | How to split analog and digital voltages | Power Electronics | 11 |
