Describe the design of a circuit that can accurately convert an analog voltage signal ranging from 0V to 5V into a digital representation
Bobbya93
Joined Jul 12, 2023
Design a circuit that can convert an analog voltage signal into a digital representation using an analog-to-digital converter (ADC). The input voltage range is from 0V to 5V, and the desired resolution of the ADC is 10 bits. Assume a single-ended input configuration.
djsfantasi
Joined Apr 11, 2010
9,237
Is this a school assignment?
Alec_t
Joined Sep 17, 2013
15,112
Welcome to AAC!
For Homework Help you are expected to post your best effort for the solution, so that we can give guidance where necessary.
38,415
Look up analog to digital conversion to get some ideas on how you (not us) would do that.
Do you have to build the circuit, or just design it?
