Analog To Digital Signal Converter
Status
Not open for further replies.
MisterBill2
Joined Jan 23, 2018
28,508
I am thinking that 8 to ten volts would be reasonable.That puts the transistor current is developing 5 volts across 400 ohms
12,287
That is what you get here!
Is that coming from your vast three months of experience?
Look at the schematic and text in post #1, and then look at the requirements list in post #16. I completely agree that this thread has been a waste of time, but probably not in the way you mean.
35,279
And the problem is, TS needs to understand what is a digital signal. Digital signals are still analog.
You don't need an analog to digital converter. You simply need to define a threshold voltage above which you define it as 1 and below it is 0. Every "digital" input circuit already does that. Every digital circuit is a 1-bit analog-to-digital converter.
And, all 1-bit analog-to-digital converters are equal but some are more equal than others, depending on the analog signal.
panic mode
Joined Oct 10, 2011
5,426
and while LM311 is faster than LM339, still neither will do 60MHz. maybe 5MHz at best and signal will be distorted. why not use something better and simpler like SN74LVC1G17-Q1?
Status
