Analog To Digital Signal Converter
Status
Not open for further replies.
820L
Joined May 14, 2025
30
I need a circuit that will convert an analog signal of up to 12 volts to a square wave of 0 to 5 volts. I tried to
simulate the circuit with LTSpice using different values for HiRef and LoRef but it failed. I attached the circuit
schematic. I hope someone can help me with this.
thanks
Papabravo
Joined Feb 24, 2006
22,111
Since the outputs of an LM339 are open collector, the diodes are unnecessary. They are backwards in your diagram and will never result in a low output.
Ian0
Joined Aug 7, 2020
13,276
An LM339 can only sink current. No current flows OUT of the output. Therefore no current can flow through your diodes.
Try turning them round.
I don't understand your description of what you want your circuit to do, but it looks like a window comparator to me.
820L
Joined May 14, 2025
30
Hi
I want to be able to feed an analog signal in and get a square wave out. Yes, a window comparator is what
I was thinking.
LowQCab
Joined Nov 6, 2012
5,102
Depending on exactly what You are trying to accomplish,
a 7555 Chip may be the simplest solution.
It Flips and Flops at 1/3 and 2/3 of the Supply-Voltage, maybe that'll work for You.
38,797
Thanks. I will look into that!
Below is the LTspice sim of a circuit using the 555 as suggested by LQC:
The output goes high when the TRIG input drops below 1/3Vcc (1.67V) and goes low when the THRS input goes above 2/3Vcc (3.33V)
BobTPH
Joined Jun 5, 2013
11,645
You say the signal is “up to 12V.” What should your circuit do when it is 1V? What if it goes negative? What waveform(s) might it be?
What is the frequency and duty cycle of the square square wave output
Is this for an actual project, a homework assignment, or just for learning?
In any case, a better specification of the input and output is needed.
820L
Joined May 14, 2025
30
I appreciate all of the responses. After giving this more thought, I have come up with what I believe to
be a set of specs for the circuit based upon your responses.
1) Attenuate the input voltage if it is above 5 volts.
2) Amplify the input voltage if it is below 3.3 volts.
3) Accept any type of waveform, ac or dc, from 1 Hz to 60MHz.
4) Protect the circuit from negative voltages and voltages say above 15 volts.
5) Provide a 5 volt square wave output with the same frequency and phase as the input.
6) Low noise output suitable for digital circuit interface.
Probably a pretty tall order.
28,240
I did have second thoughts that possibly the TS was wanting a voltage to frequency converter. But now it seems more like an input circuit for a frequency counter. That would be a good place to look for a sample circuit . My HP counter works with about 100mV to several volts.
820L
Joined May 14, 2025
30
Would this circuit work? Not sure what voltage should be used for VCC?
Status
