Digital Analog Signal
barg
Joined Dec 23, 2015
129
Hello to All,
Choosing wether Using an opto to pass a pwm signal to analog on the other side or to use a DAC.
barg
Joined Dec 23, 2015
129
The output connect to an analog controll input (0-12v) to controll motor
R1 to protect the input of the opto
sghioto
Joined Dec 31, 2017
8,716
I meant R2 as was corrected in my post.
Basically the internal resistance of the controller. If it's too low it might load down the output of the opto.
Do you know the resistance of the potentiometer if that is used?
Can you post a link to the motor?
