AMS1117-3.3 Over-heat and blow up way below max current limit
Shantanu Jagtap
Joined Nov 19, 2016
30
Hey people.
I am designing a circuit for my home automation system. To give a gist, I have a 12V 3.5A supply. I need to operate multiple loads off it.
One of the Loads is a ESp12E module.
Esp12e module ----- Max current pull = 350mA. Voltage = 3.3V.
For this purpose, I am using a regulator AMS1117-3.3
Following is my circuit diagram:
My Problem is, with this connection, the AMS1117-3.3 regulator is heating up and hence blowing up. I have read the datasheet and it says "Max output current = 1A"
What can be the problem?
Shantanu Jagtap
Joined Nov 19, 2016
30
But did you read the rest of the data sheet? :rolleyes:
Read the part in the data sheet on Thermal Considerations (page 5 of this data sheet) and how to heatsink for the (12V-3.3V) * 350mA ≈ 3W it has to dissipate.
Without proper heatsinking it definitely will overheat.
The problem is, I have searched my entire city, and AMS1117 reg is available only in SOT223 package.
The other solution I can undertake is, first bring down the voltage to 5V using 7805 and then use the AMS1117 to bring the voltage down to 3.3V. What do you think?
Shantanu Jagtap
Joined Nov 19, 2016
30
Why not just use an LM317 to bring the voltage down to 3.3V from 12V.
That device is easier to heatsink.
You are right. But, 12V to 3.3V at 500mA current pull, it will dissipate 4.4W of power. Will a single heat sink be able to cool down the reg dissipating 4.5W of power?
ericgibbs
Joined Jan 29, 2010
21,651
hi,
Have you considered adding a series power resistor on the Input side of the regulator.?
Chose a resistor value that will drop say 6V at full output load, place the 100uF cap at the junction of the resistor and the regulator.
E
Shantanu Jagtap
Joined Nov 19, 2016
30
hi,
E
No. I have not tried that. I will try what you have suggested. But won't a power resistor limit my current capability of the regulator?
ericgibbs
Joined Jan 29, 2010
21,651
Say you require an output current of 0.5A at 3.3v.
Allow 1V drop across the AMS1117, the absolute minimum specified.
Your voltage source is 12v, so you need to drop 12v- 4.3v = 7.7v,,, make that 7v.
The wattage within the resistor will be 7v * 0.5a = 3.5Watts, so choose at least a 10Watt rated 14 Ohm resistor for a continuous power usage.
The voltage across the AMS will be 1.7v at 0.5A =0.85 Watts, check this image for the AMS cooling requirement.
