Your circuit has a saturated transistor which is a turned on switch. It is not a linear amplifier.
Look at the datasheet for the 2N2222 transistor or any other transistor.
The hFE (beta) is spec'd when the transistor has plenty of collector to emitter voltage (10V) so it is NOT saturated.
The Collector to Emitter Saturation Voltage is spec'd as maximum when the base current is 1/10th the collector current (Hfe is not mentioned).
Your base resistor limits the base current to only 134th of the collector current so you are simply lucky that your transistor saturates better than most.
Some 2N2222 transistors saturate well in that circuit. Most will not because the 10k base resistor value is too high.
