Advice on High Intensity LED Current, Reverse Polarity Protection & Temperature
SnowCrash
Joined Apr 6, 2016
31
Background
My basic circuit consists of 2 x 'mid-power' high-intensity warm white LEDs hooked-up in series with a current limiting resistor sitting in-between and 2 x ceramic bypass capacitors (one for each LED), all of which are driven by a 12VDC power supply, as depicted in the following drawing:
Despite the simplicity of this circuit, I'm unclear about several points and would very much appreciate the input of more experienced members of this forum.
Circuit Technical Details:
D1A
& D2A : high-intensity warm white smd LEDs (GW PSLMS1.EC-GSGU-5O8Q-1, product page, datasheet)
R1A : smd resistor (100R/0.5W, 0805 package)
C1A & C2A : smd ceramic capacitor (0.1uF/50V, 0805 package)
I'd like to add reverse current protection for the LEDs in this circuit. However, due to severe space limitations, the best I can do atm is fit a single diode in reverse-series with the power lines as shown in the follow diagram:
The diode which I have on hand and would like to use is the following:
D3A : smd general purpose diode (BAS321, 0805 package, product page, datasheet)
Space limitations also mean I cannot fit any additional component into the circuit.
Questions
Given all of the above, these are the open questions I'm hoping to get advice on:
(1) Would the said diode (D3A), fitted in the above position, provide decent reverse current protection for the LEDs? and if not, what would be the most minimal adjustment I could make to achieve such protection?
(2) The 100R/0.5W resistor (R1A) was selected so as to drive the 2 LEDs at 0.65mA (if I'm not mistaken, at this current level, each LED introduces 3.3V forward voltage drop, so there should be plenty of headroom with a 12V power supply). Is this calculation correct? and, would this current level be a good choice for long-term operation these LEDs? and, finally, if not, what would be a better current level and why?
(3) The 2 LEDs are packed into a very compact space and I'm worried about their temperature rising to a level that would compromise the encasing structure (made of 3D printed PLA or similar material). Can someone help me figure out from the datasheet what would be the temperature of the LEDs when operating in the above conditions (0.65mA)? Moreover, any additional advice on thermal considerations re this circuit would be much appreciated.
(4) Of course, any input/correction/advice on the circuit as a whole would be very welcome!
Thank you very much in advance,
SnowCrash
SnowCrash
Joined Apr 6, 2016
31
Your leds are taking 3.3V @ 65mA, that's 2.2W, your series resistor is going to be rated at 5W Minimum ideally...
Total wattage 12V @65mA is 8W approx gives 6W for resistor droppage.
Hi Dodgydave,
Sorry, but I don't follow your numbers or method of calculation.
My calculations for the LEDs are as follows:
Single LED Power Dissipation:
PLED Forward Voltage x LED Forward Current = Watts)
Pled = Vf x I = 3.3 x 0.065 = 214.5mW
Total LEDs Power Dissipation:
Ptotal = Vf x n x I = 3.3 x 2 x 0.065 = 429mW
My calculations for the resistor are as follows:
Resistor Value:
Going by the formula for calculating the resistor value for LEDs in series:
R = (Vs - (Vf x n)) / I = (12 - (3.3 x 2)) / 0.065 = 83.1R
Then rounding this upward to the nearest common resistor value: 83.1R -> 100R
Resistor Power Dissipation:
using the formula for LED Total Forward Current Squared divided by the Resistor Value)
(0.065^2) * 100 = 422.5mW
These values are very different from what you're suggesting... so where (& why) do we diverge so radically? are my calculations totally wrong?
Dodgydave
Joined Jun 22, 2012
11,395
Hi Dodgydave,
Resistor Value:
Sorry my mistake, 12V @65mA is 780mW total, leds use 214mW, that's 566 mW for resistor...
ian field
Joined Oct 27, 2012
6,536
Thanks for the feedback, Dodgydave!
Would this diode be more suitable?
PMEG2020EJ - Schottky Diode 20V/2A (product page, datasheet)
SB diodes have significant leakage. It may not be a concern, but I'd use a cheaper basic silicon for series protection.
Inverse parallel protection is far more popular - an SB diode would clamp reverse voltage at a lower value, but basic silicon is perfectly adequate.
SnowCrash
Joined Apr 6, 2016
31
Thanks for the input, ian field!
Just to clarify, by 'SB diode' do you mean Schottky diode?
Not sure I understand the first part: doesn't the setup I suggested above constitute 'inverse parallel protection'? and, if not, could you please explain in more detail how can that kind of protection be achieved?
Also, could you please give me an example of the kind of silicon diode you have in mind (preferably in a SOD323 / 0805 package or similar) that would be suitable here?
SnowCrash
Joined Apr 6, 2016
31
Hi Ian,
Any chance you could find a moment to respond to my request for clarifications to your post above?
Thanks,
SnowCrash
SnowCrash
Joined Apr 6, 2016
31
Maybe you could clarify what you're trying to accomplish.
I thought I did just that in the first post of this thread, namely: to add reverse polarity protection to a circuit consisting of 2 high intensity LEDs and related passives (i.e. resistor & bypass capacitors), as well as advice on their optimal current and thermal behavior.
