ADG202A Datasheet Query.
pujulde
Joined Jul 24, 2013
111
Hi, everybody. I need your help regarding ADG202A IC. It's an QUAD SPST switch. As per datasheet the output is N/C, but I get normally closed only when I power up the IC(Ron=80 Ohm). Is that correct? If anybody has an experience of working with the IC, please advice.
Ian0
Joined Aug 7, 2020
13,288
THe switching devices are MOSFETs, so they will need a gate voltage to make them conduct, so it is not going to work without a power supply.
I suppose I could criticise Analog Devices for showing the MOSFETs in the datasheet as depletion mode, but they aren't.
pujulde
Joined Jul 24, 2013
111
Yes, they are depletion mode, because as soon as I power up the IC it's switching my LED, and as soon as I give 0V to the gate it turns it off.
Thanks for your reply.
