Yes it will be dedicated. In that case could i take, the 4 red wires and attach them to a DPDT switch with the 120v in the middle attached to a fan controller for speed??? and run 2 momentary for my limits connected seperatly to each direction??If that is an AC Universal motor the armature leads are reversed WRT the field hence the number of wires on the switch.
If the drill is dedicated to the scissor lift, then I would make a permanent wiring with a relay enclosure etc to perform what is needed.
Im starting to fall into posts of the same nature, Except for these damn momentarts that disconnect both directions
