This is for DAC0800. I’m looking for ADC0800LCN
That is the 18 pin NS legitimate legacy part - the OP wants the data sheet for the 16 pin version ADC0800LCNhttps://cdn.datasheetspdf.com/pdf-down/A/D/C/ADC0800_NationalSemiconductor.pdf
That is a very old part.
Good luck!
Yeah. I emailed them as well and i got the same response. I’m just baffled that you can order a supply of the chip but can’t get the information to use it. I got this chip thinking that is the same one from the Datasheet (DIP18). So i guess that I’ll be finding another 8 bit ADC to put in my project. It would be great of you could recommend another chip with similar characteristics to the original one.Just to follow up, I did write a company and asked for the datasheet. The only way they had to contact them was through an online form to request a quote. So, I did that and I put the datasheet request in the comments. I received a quote in a timely and professional manner, but no datasheet. I wrote back and repeated the request. Again, receiving a timely and professional response that included...
I am sorry that we can not provide the PDF datasheet of ADC0800LCN, but we confirm we supply you the original.
My conclusion is that they simply do not have a datasheet - so proprietary that apparently nobody does. Don't know how that could be, but if there was a large surplus resulting from some dedicated special order or something, I suppose it could happen.
So, without so much as a pin out, let alone specs, how could you possibly use it for anything other than making those little sculptures? Why not get adventurous and GUESS the pinout?
After looking at the original NS 18 pin part (@JohnInTX linked the datasheet in post #5), I thought...hmmm...what two pins could be removed and still have a functional chip (that is, function like the original NS part). In my view, the resistor network top and bottom pins (5 & 15) would be the best candidates. Even if, by some chance, I am right, that doesn't mean that everything else gets slid down a pin, but it could.
Yes, I know this is ridiculous - just use a chip that has a datasheet - but it could be fun to kind of reverse engineer something that has almost no value. It is the kind of stupid thing I would do.
So, @Attishaki can you tell us how it is that you came to have this chip and have you found the datasheet?
So, the 18 pin part datasheet was posted back in #5. This was some kind of custom/hybrid/??? that is currently available for purchase, but without a datasheet. I speculated on which 2 pins were eliminated but there is no way of knowing.Here, 18 pin part in this book, download it as PDF.
https://ia800602.us.archive.org/35/...ionBook1978/NatSemiDataAquisitionBook1978.pdf
Are you using the A/D with a processor ? If so there are UP parts out there
with mux and Vref and 12 bit SAR and/or 20 bit DelSig......
Regards, Dana.
