I would like to benchmark my ADC. I can calculate a sensitivity value based on the information in the datasheet. However, I would like to measure/benchmark this figure. Is there a standard method for doing this? How would you go about measuring accuracy of any ADC. Considering these a 24bit chip can measure down to few uV it is not very straight forward to plug in a signal gen to the inputs.
Would high ratios of voltage divider help to generate a low noise low voltage signal in uV range to feed into the ADC?
Wouldn't Johnson noise stop one from using high value resister in this case?
