Electret sensitivity
AlbertHall
Joined Jun 4, 2014
12,653
In general, will a larger mic insert be more sensitive?
Which of the two shown below will be the more sensitive?
9767 60DB:
Sensitivit: 60 ± 2dB
Directivity: Omnidirectional
Operation Voltage: 2.0V-10V
Impedance: 2.2K ohm
Frequency: 20-16.000Hz
Size: 9.7mm x 7mm
6050 52D:
Sensitivity: 56 ± 2dB
Impedance: 2.2K ohm
Operating voltage: 4.5-10V
Current consumption: 5mA
Size: 6mm x 5mm
Ian0
Joined Aug 7, 2020
13,296
The second one at a guess,
Because the figures should probably read -60dBV/Pa and -56dBV/Pa respectively.
1Pascal is 94dB referenced to 20uPa (the threshold of hearing)
but as they are not quoted correctly, you don’t really know.
Audioguru again
Joined Oct 21, 2019
6,826
Why buy no-name-brand junk (untrustable specs) from Amazon instead of excellent name-brand electronic parts from Digikey?
The inexpensive electret mics from Digikey are MUCH more sensitive than the junk from Amazon.
AlbertHall
Joined Jun 4, 2014
12,653
I hope that's right, smaller would be better.
