ACPL-C87X optical isolation
rberna
Joined Feb 27, 2017
You should not connect Vout- to GND since it is biased at VOCM (1.23V). Simply keep Vout- unconnected, and use Vout+. Remember that Vout+ is at the same offset 1.23V. Not using Vout- means you should have half the expected gain, 0.5 V/V
Vout+ = 1.23 --> Vin = 0
Vout+= 2.23 --> Vin = 2
Of course not using the differential outputs, the accuracy will be worse since there is not guarantee that VOCM will stay at 1.23V. A certain improvement could be obtained if you measure both Vout+ and Vout- through two ADC of the microcontroller and calculate the difference by firmware: at least the VOCM wandering is canceled.
These considerations are just from analysis of the datasheet, use them at your risk
Regards.
karas
Joined Sep 8, 2011
216
Regards.
Thanks so much
