dnayan12345
Joined Feb 25, 2022
I'm Nayan and I am working on a project to control the reverse flow of current and voltage of an AC power source from a small inverter circuit. This would be helpful to connect an On-Grid solar inverter to stop the feed-in mechanism to the reference power source to run the inverter in power cut from the utility.
Any solution or suggestion will be well appreciated to build such a circuit, or some device that is available in the market let me know.
Delta Prime
Joined Nov 15, 2019
1,311
Hello there welcome to AAC!
You mean when you sell the surplus electricity you generate back to the grid you want that to stop when the grid electricity come back on?
I'm a little confused.
BobTPH
Joined Jun 5, 2013
11,674
Grid tied inverters will not operate when grid power is off. If you want solar power when the grid is off, you need a disconnect switch and a non-grid tied inverter.
Bob
Alec_t
Joined Sep 17, 2013
15,163
We don't know where you're based, but for safety reasons utilities generally only allow type-approved grid-tied systems to be used. I don't think they'd be happy with any DIY modification to an approved system.
