Good on you Alec and thanks so much for the simulation!Here's a sim of the (non) 'effect' of reversing the polarity of some of the half-cycles
To cause the polarity to switch in a controlled way you would need a control signal. So you might as well just use that signal to do your toggling/flashing or whatever and not bother with actually switching the polarity. The polarity switching seems entirely pointless.a zero crossing detector beside LED controller can sense when a polarity change happened. Now upon that I can trigger some action such as toggling or a quick flash.
I think I've explained what I want to do in a simplest form possible, but if I've caused confusion, let's make it very very simple.Maybe we should back up to square one and you tell us exactly what you are attempting to do.
If rather than 32VAC you can make your source 64VAC CT (add a 1:1 or 1:2 CT transformer?) then you always have both phases, i.e. both polarities of the sine wave available. Use one TRIAC on each phase, and around each zero cross fire the TRIAC that gets you the desired output polarity. Use optically isolated TRIAC drivers with built-in zero crossing detection, then your controlling micro can be a bit sloppy with detecting and acting on the zero crossing. (FWIW as a test I used an Arduino Nano to create 5 simultaneous channels of 8.33ms pulse density modulation, feeding zero-cross SSRs for incandescent lamp dimming purposes. The resulting flicker was HORRIBLE!)T... However, I can do much at AC power supply side. That's why I'm trying to formulate a solution in this end.
Awesome man! That stuff worked!make your source 64VAC CT (add a 1:1 or 1:2 CT transformer?) then you always have both phases, i.e. both polarities of the sine wave available. Use one TRIAC on each phase, and around each zero cross fire the TRIAC that gets you the desired output polarity.
Try a different triac.I think the 6v across TRIAC is exessive
This is awesome Alec, good on you! I like the fact that all components can be SMD and price wise it's cheaper than TRIAC H-Bridge option. It does not have that strange voltage drop issue, too. Switching time is under 1us which is pretty fast. And I'm familiar with using similar MOSFETS.Here's an outline of one way of doing the polarity switching.
You should see it on a real-world circuit too, because the IR2104 driver IC boosts the gate voltage of the high-side FET to be 12V above the source voltage, and the source voltage gets pulled up close to the drain voltage, which is an AC half-wave.Is it just simulation or will I see that on real circuit too?
Hi Alec_tHere's an outline of one way of doing the polarity switching. I've deliberately simulated switching asynchronously with the AC as, for your intended purpose, I don't think switching the polarity at zero-crossings is critical. For synchronous switching the circuit would need more bells and whistles.
Thanks Alec, yes as far as technical discussions go, for sure. I was getting in touch to send you a gift card that's why I tried PM. Please feel free to get back to me if you wish so.Hi Matt
Thanks for the offer, but I prefer to keep things in the open forum so have PMs switched off.
Thanks, but instead donate to a worthy cause if you wish.I was getting in touch to send you a gift card
Thanks Alec for your generosity, on your behalf will donate to bushfires going on here.Thanks, but instead donate to a worthy cause if you wish.
