What transistor?Hi,
Can you give the transistor part number to get more details spec to review
Thank you, this is what I thought.One diode parallel to each inductive element (case 3).
Perhaps you should sit back down. ;-)I set up an experiment and you are right. The pulse current was less than the relay energizing current. For some reason I had it in my head that the kick back current was significantly larger than the energizing current.
How do you properly troubleshoot a simple circuit that isn’t working? | General Electronics Chat | 16 | |
| F | simple tester | Test & Measurement | 10 | |
| F | simple tester | Analog & Mixed-Signal Design | 2 | |
Simple project with DC motor | General Electronics Chat | 4 | |
Simple rcc flyback switching power supplies | Power Electronics | 34 |
