What transistor?Hi,
Can you give the transistor part number to get more details spec to review
Thank you, this is what I thought.One diode parallel to each inductive element (case 3).
Perhaps you should sit back down. ;-)I set up an experiment and you are right. The pulse current was less than the relay energizing current. For some reason I had it in my head that the kick back current was significantly larger than the energizing current.
