Audioguru again
- Joined Oct 21, 2019
- 6,701
Your new circuit with diodes has its load off the screen. I simulated it with a different opamp that makes no difference and I used the load I had before which also makes no difference. I do not see the spikes that you showed.
The diodes limit the output level but they produce distortion. You can reduce the affect of the diodes which also reduces the distortion but then the output level is not regulated as much.
