Hello, i made a wien oscillator with a 741 op amp the problem is it outputs a very narrow and cut off signal that is almost like a triangle wave, you can see it attached in the files.
I have zero idea why it doesnt output a normal sine wave. Im using 10k resistors and 10nf capacitors for the filters loop, a 47k trimmer as the gain loop paired with another potentiometer used as a gain adjuster.
