6 - 7.4V@10A Voltage regulator
ZweedNaat
Joined Feb 15, 2017
25
Hey guys!
I've checked a few posts on the forum and I tried several things, but nothing seems really appropriate for me.
I need to make a power supply for the servo I have (Multiplex Rhino Pro SHV Digi 4). I will run this on a car battery.
There are several things I can do. I can buy a cheap ass dc/dc converter (which I did and it isn't reliable). I can build a DC/DC converter (which I have 0 experience with and might take a lot of time). I can just take a bunch of LM317's and parallel them but they need to be cooled. Well, that is not a big problem but I have one big coolingblock. That coolingblock is connected to a bunch of other components. Those are insulated, but I don't want a voltage on the coolingblock.
Also, when the regulator/converter breaks I don't want it to put the input voltage on the output.
I checked this post on the forum and it looked very promissing, but when I simulate it myself it does not work the way I want it to.
Looking forward to your suggestions!
Thanks in advance!
ian field
Joined Oct 27, 2012
6,536
Hey guys!
Thanks in advance!
If you don't want punch through on switch failure, you should consider a transformer coupled design - its a failing common to both buck and series pass types.
A basic flyback with step down transformer should do the trick. Primary side regulation sensing is less accurate, but if you don't need input/output isolation - secondary side sensing is simpler enough.
ZweedNaat
Joined Feb 15, 2017
25
Thank you for your reactions! The lm3150 looks really goed maybe I'll even try that.
I did something that also does what I want (I think). I paralleled 2 of those LM1084ADJ chips. I think this does the trick as well, but I might be wrong. Probably not as efficient as the LM3150 but it is functional.
