i have checked that is hard to get PICAXE in Msia.. So what shld I do?
The small numbers on the schematic are just pin numbers and don't serve any purpose other than identification of the pins. They don't mean positive or negative.Sorry I'm here again. From the pdf file, at every component, there is 1 &2. does that mean posiitive & negative?
I tried to transfer the circuit diagram to stripboard using Lochmaster, however, I stuck from the very beginning where I need to select the board layout. & from the list of components, I am not able to find the timer component. Why?
Is there any software where I can automatically transfer the circuit diagram to stripboard? Sorry that I asked this because I do not know how to connect from point to point. I have only done soldering by refering circuit diagram from hobby kit where the board had already shown the holes where we need to insert the components & straight away soldering.
There are two mistakes. One is my mistake in putting only one 1000μF capacitor in the timing circuit for U2; there should be two for a total capacitance of 2000μF. The other mistake is that you overlooked the second 1000μF capacitors in the timing circuits for U3 and U4. So, U2, U3, and U4 each should have two 1000μF capacitors in the timing circuit. U1 should have only one.one more ques, hw to calculate the time obtain from the file by tracecom?
U1-U4?
10 mins: 1.1 x 510kΩ x 1000µF = 561 secs ≃ 9.35 mins
15 mins: 1.1 x 390kΩ x 1000µF = 429 secs ≃ 7.15 mins ( but 14.3 mins is shown) Is it times2? How?
20 mins: 1.1 x 510kΩ x 1000µF = 561 secs ≃ 9.35 mins ( but 18.7 mins is shown)
30 mins: 1.1 x 820kΩ x 1000µF = 902 secs ≃ 15.03 mins ( but 30.1 mins is shown)
You have gumbo in AZ?Gumbo's cooked and in refrig so had a minute to apply some ink.
I used your design and put it in computer and I think it is easier to read.Gumbo's cooked and in refrig so had a minute to apply some ink.
That's pretty cool. What software did you use to do that?I used your design and put it in computer and I think it is easier to read.
Allen
Pin 6 and pin 7 are physically connected, so they are electrically the same node. R1 should be electrically connected from 9V to that node, but it does not matter whether R1 is physically connected to pin 6 or pin 7.thx for helping, i have a doubt. R1 is connected from 9V to pin6 or 7? seems like from the schematic drawing is pin6, but in the board is pin7..
