Design Help - Countdown Timer Circuit
bans21
Joined Oct 17, 2024
5
Current circuit: using an Arduino Uno to provide clock signals to jk flipflops, then to BCD decoder.
Current problem. 7 segment is not displaying the correct number, but the jk flipflop works as it is able to show the countdown of 5 to 0 using LEDs.
Our current setup is exactly the same with the figure below. Clock signal and 5V from arduino uno.
bans21
Joined Oct 17, 2024
5
Hi bans,
Post the circuit showing the LED type and its pin numbers, and connections to the 7448.
E
the LEDs are connected to each Q output of the JK flipflop. positive to the q and negative to the ground, just to indicate if the right bit is correctly being sent to the 7448 every second.
ericgibbs
Joined Jan 29, 2010
21,591
I can see that the LED is connected, I need details of the LED type and the way it is connected to the 7448.
Post a circuit diagram showing the pin numbers of the LED and the 7448.
E
