ok, can you tell me which pin to connect the input of each resistor? I want to use variable resistorshi,
Astable as the current version, but enables variation in Frequency and Mark/Space ratio [within limits]
E
I'd advise you to avoid using work from anyone who draws schematics like that. They used connection dots, albeit inconsistently, and wire breaks... You never use both in the same schematic because one negates the need for the other.so I found this circuit
The circuit with the diodes allows adjustment of the mark/space ratio from nearly zero to 100%.ok but that calculator is for usual astable? I didnt understand what is the differencem between them? you can change frequncy mark/space ratio with a usual astable
| Thread starter | Similar threads | Forum | Replies | Date |
555 timer in astable mode, first pulse longer | Digital Design | 12 |
| Similar threads |
