555 astable unsual wired
ericgibbs
Joined Jan 29, 2010
21,601
hi ikuss,
I have already explained about the pot wiring.
This is your circuit's 4 states for the Mark and Frequency pot Limits
Study it.
E
ikuus111
Joined Dec 17, 2021
28
So I removed the pots and put one pot and a resistor . Why the freq pot changes not the frequency of pulses but the intensity of LED light? at max it stops the led...its frustating
DickCappels
Joined Aug 21, 2008
10,661
Your first schematic, which you posted twice only gives accurate results when used with the CMOS version of the part, and your is not - it is the bipolar part, in which case you need to connect the RC timing network to the power supply, pins, 7, 6, and 2, as shown in ericgibbs's circuits shown in post #22.
With the bipolar NE555P pin 3 is only useful as an output, not to drive the timing network.
ikuus111
Joined Dec 17, 2021
28
ok the frequency is not accurate , I wired the circuit as that, but why the potentiometer varies the current-led intensity and not the frequency? I burned one while trying to wire it everyway.
djsfantasi
Joined Apr 11, 2010
9,237
Cha
How do you know the frequency isn’t changing? With the calculated values, what’s the frequency range you’re expecting? Any frequency over 50Hz won’t be visible. It might affect the brightness.
ericgibbs
Joined Jan 29, 2010
21,601
hi,
The simulation shows with those component values, the slowest flash rate is about 5 per second.
Try increasing the 4.7uF to say 10uF or 22uF
E
ikuus111
Joined Dec 17, 2021
28
Cha
because the frequency was constant at 1 flash every 6 seconds , but I have an extra 555 and replaced it now it seems to work//// it was a new one, they can be broken from factory it seems.
ikuus111
Joined Dec 17, 2021
28
Why in the usual astable circuit if I use a potentiometer in place of R1 if I turn the knob to the lowest resistance the LED is off and the pot makes sparks? It works with a resistor.
