Can you step through your circuit to see how it would count of invalid states if, for example, your simulator initialized the counter at 0?I forgot to change 2 AND gates to OR at Kc and Jb.
Sorry but cant understand, step through? You mean send the circuit?Can you step through your circuit to see how it would count of invalid states if, for example, your simulator initialized the counter at 0?
Since you coded invalid counts, such as 0, as don't cares. How would the counter count to a valid number?Sorry but cant understand, step through? You mean send the circuit?
Yes, I know its bad but I need this to don't get lost at these things. Thanks for improvement tips.I've circled some areas in red where you can improve the readability of your schematic:
Are you in the habit of reading binary numbers backwards? If not, why did you arrange your indicators backwards reading?
Can you explain why that happens?everytime start at 0 but after 1 "cycle" it would work fine from 3 to 12
