A good choice for synchronous buck converter for deliver 5.1V at 3A on a Rpi4B via USB-c port?
TheRoBoTBiLL
Joined May 26, 2020
18
First of all, which company's ICs should I look at, Texas or Analog?
I want to design a synchronous buck converter to deliver 5.1 VDC at 3 A maximum to a Raspberry Pi 4 B via a USB-A port.
My power source is 24VDC from a power supply at 230VAC to 24VDC.
My first choice is the LMS3655 and the second is the TPS54538. But what is the best to have big switching frequency or small?
I already designed with webench but i am not sure about my choice.
Irving
Joined Jan 30, 2016
5,070
Of those 2 I'd marginally opt for the TPS54538. Why?
In no specific order.....
1. Simpler functionality, no unnecessary complexity
2. Slightly lower component count
3. Higher frequency -> smaller/cheaper inductor (6.5mm sq/£2.95 v 10.5mm sq/£3.20)
4. Cheaper part (£2 v £5)
5. Newer device (2024 v 2018)
6. Smaller part, fewer pins (9 v 22)
lichurbagan
Joined Jul 4, 2025
121
Whatever company you choose, make sure your ICs are original, not knock-offs.
