4-bit synchronous counter which is counting upwards from 3 to 12?
Sedus
Joined Mar 25, 2021
31
I finally made simple 4-bit synchronous counter and somehow its start from 3 as well, but I have no idea how to solve completely. I know how to do with asynchronous counter but this synchronous now. I insert my basic 4-bit synchronous counter.gdgdfgd.png
ericgibbs
Joined Jan 29, 2010
21,622
hi,
In an actual circuit a Clear pulse would be applied, usually at power up.
This ensures all Counter are in the cleared state before applying the count input pulses.
E
Sedus
Joined Mar 25, 2021
31
Good for you. I tried to figure out the whole thing but I didn't get any further, I understand how synchronous counters works but thats it, I can still trying with this preset and clear thing but I dont know what am I exactly doing. I can easily do asynchronous counter which is counting 3 to 12, but this...
dl324
Joined Mar 30, 2015
18,490
If you post your work, we can see what method you're using and where you're having problems.
Synchronous counters don't rely on preset or clear.
The counter you were asked to design isn't very complicated. I only needed the 4 flip flops and half a dozen gates.
Sedus
Joined Mar 25, 2021
31
So, I used AND gate which is connected to 1,4 and 8 Q output so it should switch at 12, and the other side of gate I connected to 1 and 2 P input so it should be start at 3, it works but the problem is when the counter switch from 7 to 8 for something the gate's input value was 15 instead of 8, somehow 1,2 and 4 output is delayed a little bit before going low when switch to 8. So I made a 3-7 synchronous counter by mistake. I cant fix this, so here I am, I tried, I would appreciate some real help or guidance about I'm on the right track or completely wrong?
dl324
Joined Mar 30, 2015
18,490
Textual descriptions of circuits is a non-starter for most of us. If you're serious about getting help, post a schematic and show your work.
