I'll grab that tonight if you feel that's still a pertinent detail.You have still not given us the resistance of the solenoid as requsted in post #8
Les.
This is pretty far over my head, but I did gain some understanding of what I'm looking at when considering putting my own transformer/rectifier assembly together.You have to read this: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj7xJqo19LSAhXJVyYKHdjqCLoQFggcMAA&url=http://www.hammondmfg.com/pdf/5c007.pdf&usg=AFQjCNFPNgWFEfkADk5oUMa3KwjgqL3-YA&sig2=jqZPTtIGU0DRvNTeKoLgPw
The deal is that the DC voltage after rectification is aprox sqrt(2)*Vac(secondary) AND the DC current is about 0.62 of the AC current.
the rule of thumb for capacitance is >1000uF/Amp.
Note that these http://www.farnell.com/datasheets/612776.pdf diodes have a max drop of 1.1 V. The max forward voltage per diod eis dependent on current. Two voltage drops need to be subtracted. i.e. Vdc ~= (Vac-2*Vd)*sqrt(2)
That's just the resistance of the solenoid from Les' question in post #23.So, it's now working?
Add the suggested diodes.
Units matter:I get 26.3 with a multimeter set to 200.
Tachometer suddenly died, wondering if the chip is likely still operational. | Technical Repair | 143 | |
Editing is broken suddenly? | Feedback and Suggestions | 2 | |
| L | Cruise Control FSM not outputting anything. BDF attached | Homework Help | 1 |
