Jon Chandler
- Joined Jun 12, 2008
- 1,621
You may be right. Or the diode is installed backwards. Or there's a bad connection on the breadboard. Two of those should be trivial to troubleshoot given a basic understanding of the chip.
I believe that the diode is installed correct, and I have doublechecked the connections.You may be right. Or the diode is installed backwards. Or there's a bad connection on the breadboard. Two of those should be trivial to troubleshoot given a basic understanding of the chip.
There is already a 10K pull-down resistor, the diode will need to be between the capacitor and the reset pin, with the resistor between the rest and common.Re post #280. I did wonder about the same thing as the capacitor would slow the rising edge down. If this was the case then I would expect the counter to be in state 3 with the reset pin high. If a diode was added from the power on reset then a pulldown resistor would also be required on the reset pin or it would be left in a floating state.
Les.
You're right, it doesn't need it now that it has the pull down resistor. Somehow I missed that when I added the mod to the original circuit!R2 in post #291, is not required, the capacitor should discharge during any reasonable power off time. Also, the pull down resistor can be greater than 10K ohms, 27 K should work as well.
It sometimes svings between 4.5 and 5v.What was the supply voltage to pin 16 of the 4017 when you took the readings ? 2.8 volts is neither a logic high or low if the supply was 5 volts. I think the circuit may be oscillating due to the slight delay caused by the capacitor.
Les.
Better, but it counts to 4 and sometimes miss a press. Still 2.8v on pin 7 at count 3.
If there is nothing else connected to any parts of that circuit, you either have a leaky capacitor or a defective 4017. Try changing one or the other! Or maybe your breadboard is faulty? Move the circuit to a different section and rebuild it.Better, but it counts to 4 and sometimes miss a press. Still 2.8v on pin 7 at count 3.
Confused, should I try another type of 4017 ?
I've used it with the 4017AE's that I have and it works just as well as with the B series.I would try a 4017B, as in "buffered".
I have used that reset circuit many times, and it never fails, but I don't have and 4017s from the Jurassic period.
10k
,1uf
914/4148
