Jon Chandler
- Joined Jun 12, 2008
- 1,644
There are plenty of good tutorials for using EasyEDA in internet-land. This one is all cued up for you to the right spot. It's not that difficult after all the hard work has been done for you.
Auto arrange? Ha. Ha. Ha.5) auto arrange (?) remaining components
Maybe redo 3-5).
Yes, same as switch (possibly through-hole in print if too long). Adapter 24v 5a jack 2.5*5.5What is the output voltage and current of the power supply you're going to use? The barrel jack has to be rated for this load. Jacks rated for more than 5 amps seem to be scarce.
Are you planning on the jack going through the metal trim in the same direction as the switch? If so, you want a through-hole straight jack. Horizontal (usually) means the jack, switch, whatever, is at 90° to the surface of the board. Straight or vertical means perpendicular to the surface of the board.
Mouser lists a straight through-hole jack jack rated for 11 amps – it's a Switchcraft part but they only have 30 in stock. It looks like it may be obsolete since you have to dig to find it on Swichcraft's web site. (Sorry, I don't recall the part number and I'm running late for an appointment. )
You may not need that high of current rating as discussed in the first paragraph.
Searched everywhere, but you are right L721A is best because of the long nut. Maybe ECLyxun DC-025 with 9mm nut, but I can't find the specs.This Switchcraft jack could work. Read the notes on the drawing. Every word is there for a reason.
● There may be shorter power jacks available. Please search if you like.
● I suggest a plastic sleeve to fill the gap around the jack. No, I cannot suggest anything in particular. No, I do not know the dimensions needed.
● The D-hole through the circuit board is critical. Don't be lazy in this detail.
This is the end of my free advice. Not my circus, not my monkeys. I take no responsibility and make no guarantees for anything I have suggested. The details and suitability your responsibility. The free help level has been far exceeded.
