24V 5A 3-state capacitive touch switch (not a dimmer, without relay)
oslosl
Joined Jan 13, 2023
270
Because I prefer the 40106 for the touch sensor
Breadboard tested the curcuit successfully, but the touch is too sensitive or something, if you connect a wire or the frame to R1 the red LED sometimes turns on forever. Please advice ? Or do I have to use a small push button after all with a switch debounce curcuit ?20230202_194532.jpg
sghioto
Joined Dec 31, 2017
8,642
Not surprised. The frame is too much metal for the touch plate.
Try increasing the value of R1, start with 1meg
Ideally the touch plate should only be about 1 square inch.
I'll check to see if I can reduce the sensitivity also.
oslosl
Joined Jan 13, 2023
270
Ok. Maybe that is related to my next question. Why does a simple RC switch debounce curcuit not work with this setup ?
oslosl
Joined Jan 13, 2023
270
I like this 10 mm push button with blue light power symbol, embedded in a 10.5 mm hole in the aluminium frame.Screenshot_20230205_171020_AliExpress.jpg
oslosl
Joined Jan 13, 2023
270
Is there a way to make a 3 x 21700 battery pack (external BMS), 12V 4.4A, using spacers, but without soldering or spot welding on the batteries ? What about cold, chemical soldering ?
Sensacell
Joined Jun 19, 2012
3,786
Breadboard tested the curcuit successfully, but the touch is too sensitive or something, if you connect a wire or the frame to R1 the red LED sometimes turns on forever. Please advice ? Or do I have to use a small push button after all with a switch debounce curcuit ?View attachment 286645
You can make this touch-sensor idea work:
1) Make sure your metal frame is completely insulated from all the electronics, just one connection - the touch point.
2) Add a large metal plate to the REAR of the frame, it must be INSULATED from the frame- connect this to the GROUND of your electronics.
Now your touch circuit has capacitive coupling to the world (GND) and a nice big separate touch plate at the front.
3) adjust the sensitivity of the circuit to obtain the desired results.
I has little chance of ever working without the large reference electrode at the back.
oslosl
Joined Jan 13, 2023
270
Thanks. Worth a try. The aluminium frame is already isolated from anything else, only mounted around the MDF cabinet using strong doublesided adhesive tape. How big shoul the plate be ? Could you make a drawing sketch ?
