24V 5A 3-state capacitive touch switch (not a dimmer, without relay)
Sensacell
Joined Jun 19, 2012
3,787
Thanks. Worth a try. The aluminium frame is already isolated from anything else, only mounted around the MDF cabinet using strong doublesided adhesive tape. How big shoul the plate be ? Could you make a drawing sketch ?
You could just laminate a piece of MDF with aluminum foil? make it big, the whole back is good, but leave a 2 inch gap from the outer frame to reduce the capacitance between the two.
Make a solid connection to the foil with a screw or equivalent.
oslosl
Joined Jan 13, 2023
270
My only concern is how it would affect the bluetooth reception (only a small wire antenna inside the cabinet) ?
oslosl
Joined Jan 13, 2023
270
What is the simplest debounce curcuit I can make for IC 4017 ? Or should I get a special 4017 with trigger on clock input ?
sghioto
Joined Dec 31, 2017
8,751
I don't see the switch. Are you simulating the switch by touching the jumper to the 5 volt bus.
If so that might have too much bounce.
oslosl
Joined Jan 13, 2023
270
I have a touch button switch, but I am also using the jumper to 5v, but nothing happens.
It kind of works if I just pull pin 14 to minus using 100k and to 5v via the button, but often bounces.
