You could just laminate a piece of MDF with aluminum foil? make it big, the whole back is good, but leave a 2 inch gap from the outer frame to reduce the capacitance between the two.Thanks. Worth a try. The aluminium frame is already isolated from anything else, only mounted around the MDF cabinet using strong doublesided adhesive tape. How big shoul the plate be ? Could you make a drawing sketch ?
Make a solid connection to the foil with a screw or equivalent.
