12v not enough?
lastone
Joined Oct 29, 2019
10
I have a deep cycle battery in my camper.
Powering my TV from it. is no problem however there is no sound.
When I switch on the engine the oscillator churns more voltage into the battery and then the TV speakers work.
After turning off the ignition there is sound for a short amount of time until the voltage drops back down.
Why then does the TV function completely fine but for the sound?
lastone
Joined Oct 29, 2019
10
It's a Voxson and originally had a transformer to be used on 240v input but yes it is a 12v TV. I have attached an image for further info.
You mean the voltage when the sound goes? Because the picture and operational function of TV is completely fine just the lack of power to the sound.
38,665
The sound starts to lessen around 12.46v
Yes, I meant when the sound quits.
12.46V is a normal voltage for a 12V lead-acid battery, so the problem apparently is that the TV was not designed to operate on a 12V battery.
How much current does it take?
Measure the battery voltage and compare to the voltage at the TV when it is operating.
You might may able to gain a few tenths of a volt by using larger wires directly to the battery (with appropriate fuse in series, of course).
Otherwise you could use a buck-boost switching converter to output 13V or so, independent of the battery voltage.
Again, need to know the current the TV requires.
Papabravo
Joined Feb 24, 2006
22,102
The label on the TV says 6A. Hard to know if that is average or peak demand
LesJones
Joined Jan 8, 2017
4,517
Where are you measuring the voltage ? At the battery or directly at the power connector to the TV when it is switched on ? I am thinking that the problem could be voltage drop between the point where you take the voltage reading and the 12 volt input connector to the TV.
Les.
lastone
Joined Oct 29, 2019
10
Les.
I measured both at the battery terminals and at the wired sockets a and the voltage was the same.
When I measured the current to the TV the voltage was below 12v and so the TV would not power on with the multimeter attached.
Alec_t
Joined Sep 17, 2013
15,149
How old is the battery? Maybe it can't provide the 6A required for sound plus vision (but in that case you would expect the voltage to sag).
BobTPH
Joined Jun 5, 2013
11,609
This sounds very odd to me. Circuits do not generally,unless specifically designed that way, cut off sharply at any particular voltage.
I wonder if a mute pin on the amplifier chip might be pulled up slightly too much resistance?
Do you still have the AC adapter that it runs on? Have you measured its outpit when running the TV?
Bob
lastone
Joined Oct 29, 2019
10
I found this very suspicious too, Bob.
So what would I be looking for exactly?
I don't have the AC adaptor but could try and find one.
AlbertHall
Joined Jun 4, 2014
12,638
I set off a long car journey and turned on the radio all was well as long as the engine RPM was lowish. At higher RPM the radio cut out. I knew that I had a repair job to do on the radio - at 12V it was fine but at 14V it wasn't.
When I arrived at my destination I discovered that the battery would no longer turn over the engine. It turned out that the alternator regulator had died and the charging voltage was around 19V so both alternator and battery needed replacing.
So actually radio worked at 12-14V but cut out at 19V. I doubt it was designed like that.
bwilliams60
Joined Nov 18, 2012
1,450
Is this running off of the chassis battery or do you have a deep cycle stand alone battery (house) to run this off of? Is it the only thing running when you are doing these tests on this battery?
