I'm working on a synchronous buck converter with an input voltage of around 60V, and I'm planning to use the IR2302 gate driver (https://mou.sr/4jqqFSB) to drive the two MOSFETs. According to the datasheet, the minimum Vcc for the driver is 5V. I’m considering using the default 5V from the USB-C port as the Vcc for the gate driver. I tested this setup on a breadboard, and it seemed to work reasonably well, but I’m not fully confident that it's robust or reliable enough for the final PCB design. I’d prefer to use the default 5V from the USB port, because otherwise adding a separate boost converter would increase complexity in the PCB. I wanted to ask if anyone has experience with this approach or any suggestions that might help.
Thanks!
Thanks!
