MisterBill2
- Joined Jan 23, 2018
- 28,246
I interpret that reading as 00.9 millivolts, BUT I do not believe it. I was expecting a six digit voltmeter, or maybe an 8 digit one.
Read the thread. The problem is that the signal is active low, when he expected it to be active high.Right now I suggest making a direct connection between the two trigger terminals of the timer and see if it still triggers.
OK, I did miss that post. Sorry about that.Read the thread. The problem is that the signal is active low, when he expected it to be active high.
This sparks a thought: On chips like a quad NAND gate (and many many others) you want to tie all unused inputs either high or low. Leaving an input floating leads to oscillation that can destroy a chip. I think the resistor idea is probably well suited, providing I have an understanding of this thread thus far. Don't shoot me (or at me) if I'm wrong.Right now I suggest making a direct connection between the two trigger terminals of the timer and see if it still triggers.
My guess is that it is looking for a contact closure to start timing, not a voltage. So I suggest reading the instructions again, very closely. Then disconnect the wire and see if it starts timing when the power is switched on. The problem does not make sense any more.
https://www.amazon.com/HiLetgo-Chan...ocphy=9007248&hvtargid=pla-343992463804&psc=1The simplest way to start the timer when the winch is driven in the "Pay Pout" direction will be to use a single relay with a diode in series, connected in parallel with the motor, with the polarity of the diode set so that the relay operates and starts the timer when the "unwind" rotation is selected. Only two components, and easy to mount 12 volt relays are commonly available, 24 volt relays also available but not as common. And a cheap one amp 100 PRV diode, such as a 1N4001, or similar, would be all that is required. Simple, Cheap, and very easy to understand. And no modifications to the present system.
Thank you @MisterBill2. Please confirm if I understood correctly how-to wire 5pin relay for my needs, see file "new.jpg". Research tells me pin#86 once activated will then energize pin#87 which then I can use to start timer A103-006.The Bosch relay is the type I was thinking about. The other one gave no definitive explanation of what would trigger it and what would not trigger it.. The simple relay. plus a single diode, will be easy to connect so that only one polarity will operate the relay. in addition, the contacts are isolated so no noise will be sent to the timer from the motor, because of the relay providing better isolation. In addition, the Bosch relay is simpler to mount and connect.
Also, there are at least a dozen brands producing an interchangable relay with the same connection arrangement.
