In a month's period, I had accomplished calibrating the lighting system of the Home theater. There are so much things to do such as designing the android application graphical user interface (GUI) and interfacing a cooling system to the device. I actually received the device before the end of March, quite not enough time left to finish everything, because of the ongoing lockdown in our country. I plan to continue doing the system even after the contest and I hope to get good results from the...
In this part of the blog, I used the Light Sensor installed in the SAM-IoT WG Development Board to determine the maximum light output and minimum light output for the LED to be used in the lighting system. In the video, a LED light was light with maximum voltage to see the response of the sensor to the output. The output value will be used to calibrate the four levels of lighting conditions as stated in the previous entries of this blog. In the video above, the response of the...
In this project, I have used connection via SOFT AP. At the start, I was having a problem with why the board is not connecting to the network. There were two possible reasons that I discovered: The board is only limited to connect to 2.4 GHz WiFi connection and since my WiFi is already 5G, it's having a hard time to connect. SOLUTION: I opted to use my mobile phone as a hotspot. The board is having a hard time authenticating passwords with special characters. SOLUTION: I opted to change...
Here are the materials needed in the implementation: SAM-IoT WG Development Board Temperature Sensor Light Sensor WiFi Module LED Lights Red Blue Green Yellow White Mobile Phone
Entertainment has been the past time of many people amidst the ongoing pandemic because of several lockdowns. Most people tune in with their television to watch movies from different streaming service providers such as Youtube and Netflix. Amidst lockdown, many of us have shifted to go online with several cinemas closed and many movies moving to online streaming. This project is about automating a Home Theater using the Microchip Technology SAM-IoT WG Development board. The idea is to...
