ZVS driver simulation not working
icantalktosneks
Joined Apr 23, 2021
36
I tried to make a ZVS driver simulation, but I cant seem to get any output.
After removing the power supply via an inductor to the center tapped transformer, it gives me an output waveform
I tried directly connecting without an inductor, but the output remained a flatline.
ericgibbs
Joined Jan 29, 2010
21,439
hi ican,
It is a common problem with simulated oscillators, they are so well balanced, they will not run.
In the real circuit, the component tolerances are usually a little unbalanced, so they run OK.
Adding a .IC offset can give them a kick start.
You could also try .tran 0 10m 5m startup
E
icantalktosneks
Joined Apr 23, 2021
36
hi ican,
E
ok thank you, I've been trying to get this working for a whole day now. But what does .tran 0 10m 5m startup do?
Also while I have you here may I ask what determines the oscillating frequency of the ZVS driver if I hook it up to a transformer and a capacitor in parallel with its output as shown below. Is it still determined by the LC oscillator at the primary coil, or must I factor in the values from the secondary coil?
eetech00
Joined Jun 8, 2013
4,705
Use the "startup" option.
.tran 50m startup
"start' ramps all voltages sources from 0 over 20u seconds.
