ZK-4KX: As battery charger.
MrAl
Joined Jun 17, 2014
13,893
You described the protection quite clearly. It would be a simple but worthy addition to any power supply cum charger. If it is not asking too much, is it possible to post a circuit diagram. It will be a big help.
You mean the protection circuit?
First you connect a diode in antiparallel to the original output, and that is no longer the actual output.
Then, just connect a fuse between that old output and the newly formed output, positive lead.
The ground lead can stay the same.
So it's just a diode and fuse.
The diode should be at least a 1N5400 series but maybe you want to go bigger on that.
Kalikut
Joined Nov 19, 2021
12
MrAl
Woahh! The ingenuity lies in its simplicity. I wonder why I have not met this circuit before. Might have but perhaps never paid attention. :rolleyes:
At any rate, thank you so much for sharing. I'll file this in my head as a handy, "go to", output protection. Much obliged!
MrAl
Joined Jun 17, 2014
13,893
MrAl
Hi again,
You're welcome. BTW the fuse should be a fast-acting fuse of course, and the diode should probably be a nice big one maybe even bigger than the 1N5400 series type. The whole idea is we want the fuse to blow before the diode(s) blows out.
Kalikut
Joined Nov 19, 2021
12
Right! Perhaps even a parallel pair of 1N5400s or bigger. And the lowest possible amperage rating for the fuse. Again, much appreciated.
