Greenworks Battery Charger Flashing Red Light
wayneh
Joined Sep 9, 2010
18,183
Greenworks markets a range of power tools such as leaf blower, snow blower, string trimmer, etc. They mostly use a common 80v battery and charger system. I happen to have a couple items and each came with a battery and a charger. They're all interchangeable. The extra battery is handy when you have a big job, like leaves in the fall or snow in the winter. A spent battery can be almost fully charged during the time you're using the other one. After two or three batteries, I'm ready for a recharge myself.
Anyway, one of the chargers is having a problem: Charging starts as usual (green light, fan starts) but soon stops and the red warning light flashes. This typically indicates a problem with the battery, such as overheating. But I know both my batteries are fine. Everything works if I avoid this one charger.
So I took the charger apart and dug in, only to find it's far more complex than I imagined. About the only thing I know to check is that the battery is in fact connected to the PCB. The symptoms I have could result from the battery's thermistor not being seen by the charger, or maybe even a poor connection to the power poles.
Anything else to consider? I'll get some photos as I dig in. Here are some pictures of an identical unit getting a fan replacement:
https://www.ifixit.com/Guide/Greenworks+Pro+80V+Battery+Charger+Cooling+Fan+Replacement/159384
Here's a video where the battery pack is the problem, same symptoms at ~2:45 but a different cause than mine:
wayneh
Joined Sep 9, 2010
18,183
Update. I put the battery pack in place and confirmed that battery pack voltage was detected on the PCB. Charger unplugged.
Here's the pack's 4-pin port label:
The corresponding wires are Black, Blue, Red, White for – , Ω, C, +. The voltage between – and + is about 70V (the pack is at a low SOC).
That voltage was detected where the white and black wires contact the board, labelled there as BAT+ (white) , COM (blue), CHG+ (red) and GND (black). The latter two are heavier gauge and I assume they carry the charging current.
When I plugged in the charger, the fans spun up but I never saw the battery voltage bump up at all. So, it's not initiating a charge before it shuts itself down.
I'm not sure how to interpret the Ω voltage reading. It acted like there was a capacitance there; the voltage started high but quickly faded. That's not what a simple thermistor loop would do. I've since learned that these battery packs have an advanced BMS built in to handle cell balancing, overload conditions and so on. So I have no idea what to expect to see at the C and Ω ports.
wayneh
Joined Sep 9, 2010
18,183
